So my headlights were milky and yellowing (one side much worse than the other) so i wet sanded them down with 400, 600 and 2000 grit, cleaned the headlight with some alchohol and then covered them with some uv resistant clearcoat.
My problem is that one side looks way better than the other. The side that started out the [censored] finished the [censored], i also have a bit of orange peel (which im probably going to wet sand a little tomorrow) but im wondering if i should resand the [censored] one down and go over it again with the 2000 grit and reclearcoat it? And if i do how long do i need to wait after my first clearcoat job (the messed up one) before i can sand it down?
Not as clear
Looks alot better
Not as clear
Looks alot better
