I have a 2011 BMW 335D w/ 40k miles. It's starting to have some issues which I believe are all related to carbon buildup. I have a 1/2 gallon of FP60 (from LCD, Inc). The BMW is no longer under warranty but has warnings around the gas filler not to use additives (or biodiesel greater than B7).
Is it possible that a few tanks treated with FP60 could solve the carbon buildup issues & not further damage the 335D?
FWIW the issues I've had in the past 5 months: Temp sensor in the Diesel Exhaust Fluid (DEF or Urea) tank. Temp sensor error in the air intake. Leaky Diesel Exhaust tank (twice). MAF sensor error. The dealer did replace the entire DEF tank with sensor under the emissions system extended warranty & fixed the leaks both times. 1 time they blamed it on a misplace gasket. 2nd time they blamed it on overfilling the tank. They now suggest that I replace the intake & MAF now for $770. Engine light is on & engine is operating under "reduced power."
Thanks All!
Thanks All!
