Originally Posted By: KrisZ
Fluid Films is quite pricey in Canada and does not hold up all that well in the wheel wells and high wash areas. Their gun is also very expensive considering that a similar undercoating gun can be had for about $20-$30 at Princess Auto.
As for undercoating, try finding some oil distributors in your area, they usually carry some type of oil or dripless undercoating. I use Monarch Oil, located in Kitchener and they sell theirs for about $20 a gallon. It's pretty thick and doesn't wash off was easily and can be thinned with WD40 or some other thin oil.
I managed three applications with one gallon.
For inside the door, trunk, and quarter panels I use rustproofing in a can and a straw. Canadian Tire carries Rust Cure by Corrosion Free. It's a bigger can and cheaper than FF can. It is also thicker than FF and is excellent for external touchups as well. A can of Rust check with a green cap is also very good.
In other words, FF is OK, but In Canada we have better and cheaper options available.
Hi Kris,
Can you send me a PM with the contact information for Monarch Oil. I did buy the gun at Princess Auto when it was on sale last year. I just never used it.
