My 2010 CVPI has an OEM oil cooler on it. The hoses on it are a known issue and with time/miles they will begin to seep and require replacement. For basically the same price of replacement I can just delete it and not have to worry about it. The car is not abused, tracked, raced and there is no extended idling.
Is there a real benefit to having an oil cooler on a daily driver? I don't believe it has a thermostat and the cooler is piped into the lower radiator hose.
A potential benefit is I can run the FL-820S size filter instead of the smaller FL-910S if I delete it.
