Well a lot of the tears I have seen posted looked self induced to me. The material is tight by the seam and doesn't take a big push to tear it. Maybe torn from pushing to look, maybe torn from the cutter hitting it, most likely the tool in my opinion. When I was all done with mine this weekend (x3) I was able to push the pleats to the side and duplicate the same tears I have seen here. And really wouldn't a tear from pressure be in the inner fold of the pleat, not across it. Im not saying anyone did it on purpose, what I am saying is push the pleats to the side next to the seam and you get the tear that looks same as posted. As far as looking for tears as I said I ran a probe between each pleat, a dull rounded tip aluminum flat probe that I use to remove O-rings and they were all solid. I was going to go get the tears I made out of the trash and post them but the garbage truck just left with them. Really our garbage goes on holidays, every Monday no matter what. Anyway next Pure one I cut I will post it before and if it is fine I will duplicate the tear and post that.
In fact I will disregard any Purolator tear pics if the can was cut by anything other than a filter/pipe cutter. Anything cut with snips or saw will be ignored by me as possibly self induced. If you really want to cut filters spend the $40 and get the right tool to take the self induced possibility out of the equation.
My guess is when cut properly those with the tears are real, caused by the wide spacing of the pleat at the seam taking a big pressure drop because the rest of the pleats are packed so tight the oil cant get between them, especially when cold. Anyway for that reason once my old stock is gone Im moving to something else. Fram ultra for now.
