I'm flushing my 2012 Hyundai Elantra's coolant soon and I'm going to replace the thermostat. 162K miles on car, flushed once before at 80K. Is it worth the extra work to remove old thermostat, replace cover, flush and then install new thermostat and fill and bleed. I ordered one of the Lisle spill free funnels to use for removing air since there is no bleeder on this car and it took awhile last flush to get all of the air out. If going with pulling the thermostat method, one new gasket should be sufficient, don't you think? Thanks
