Figured a had to post about this... my fault, i'm a little [censored] at myself. Its a learning experience. Hopefully help/remind others as well.
So the GF's DD is the lancer in sig. Overall its a rusty POS but it works. During last oil change, i found passenger side wheel a little loose at 3 and 9. Moved it around and looked for what had play. Clear as day it there was a tie rod end with a busted boot and it had play in there. I didn't bother going on after i saw the bust boot and all grease leaked out.
So i ordered up 2 moog tie rod ends. Figure i'll get them done as a pair and get an alignment done on my only day off this month. So friday night after work(today) i go ahead knock out the tie rods. Annoying cotter pins didn't work with me had to smash them. All said and done, i check the play and OH POOP still a little play but not as much as prior.
Problem being BALL JOINTS! So now i have to do more work at a later time because i jumped the gun, saw a broken part and thought that was the ONLY thing wrong with the car. Now i might have to wait another few weeks before i can address this. So just a reminder for you guys to look beyond the single broken part.
The kicker now for me is... since i did the tie rods, alignment (toe) could be off, should i risk no getting the alignment until i get the ball joints done too. Shop might not want to do an alignment with bad joints, might just suck it up and pay to have this done.
BIG FAIL on my part.
