Hi there,
I have 2 x 5 year old Volvo IPS 600 drives. The drive units take 14 litres of SAE 75/90 API Synthetic oil. Volvo direct that their oil must be used in the drives. The spec in the handbook is as above and the same oil is generic to many Volvo outdrives. The oil cost is high. A drive service is pretty much an oil change grease a few things, change a filter, check sea cocks and change anodes. Oil & haul out is the big cost.
IPS drives are essentially gears, shafts bearings and 4 seals in the mid and lower sections and a hydraulic box with 2 sets of clutch packs, oil pump and more shafts, gears, Solenoids, Electronic power steering motor etc in the upper unit.
Volvo does not allow non dealers to access workshop manual data, pretty tight lipped. Volvo do not provide data sheets for their oil. It will not be made by Volvo, but could be made to their exact specification - Volvo oil does not seem to stop units from breaking or leaking.
I had thought to use Amsoil, but read a comparison that I did not like - Egg beater test - pretty interesting. Also read up on a Penrite marine gear oil. Anyone out there who is working on these older units using a lower cost oil with success?
Thanks in advance
Thanks in advance
