- Joined
- Jul 11, 2014
- Messages
- 4,118
Its OK java... we're just picking on you. Its hard to believe that with CAFE, any automaker would recommend a 20w50.
You are in OHIO and do not need that thick of an oil.
Page 8-8 of the 2016 Sorento owners manual...
20w50 (but no 10w50, 15w50, 5w50)...
15w40 (but no 10w40)
10w30
5w30, 5w40 (but no 0w40)
Its good to see a 40 and 50 grade mentioned in an owners manual.
For better fuel economy, use a 5w30... hahahahaha not saying "best"
I probably wouldn't use 20w50, unless you mod the engine for more HP.
I'll stick with my 0w40(Mobil1, Pennzoil, Castrol) are easy enough to find at local autopart and department stores.
5w40 is also an excellent choice. Mobil1, Castrol, Pennzoil, Delo, Rotella,....can be found.
You can also use any of the mail order boutique fluids...Amsoil, RoyalPurple, Neo, Torco, Synmax, Redline, .....
With the failures of these turbo2.0's, turbo1.6's, nonturbo2.4's, I'd probably avoid 5w30, 10w30.
And, your oil change interval is 3mo/3k for severe service, or 6month/5k for unheard of non-severe service. Remember to check and top off oil at EVERY fillup. Keep it full always. And, I would always stick with a synthetic oil.
Enjoy the vehicle.
BTW, Castrol/Mobil1... make a good 5w50/15w50/10w40... I would not fear any non-mentioned grades. They overlap easily with Kia's limited selection.
10w30
Enjoy the vehicle.
