Popsy
Thread starter
Originally Posted By: Greasymechtech
10w60's shear quickly. Its probably already a 50 grade and will likely be a 40 grade by the next oil change. Coincidence and look elsewhere for the temperature rise.
That's what I thought (shearing), and what I feared (having to look elsewhere).
Originally Posted By: edyvw
How about you change rubbers on the valves? Oil will not solve issues. You cannot go indefinitely thicker with oil.
Also, for Alfa, try Selenia 10W40.
What's so special with Selenia oil? I have some Selenia Turbo diesel, the jug is new and already leaking (they were all leaking when I bought it), as if it is wanting to escape to go into my Fiat^^ Bought it, but never tried it, still on the shelf in my garage.
As for rubbers on the valve, it could help, but there's most likely a compression issue too...and my friend doesn't want to pay more than basics (oil, filter, brake pads).
For the sake of trying, I've got a jug of Helix HX7 10W40 I'm almost ready to sacrifice for my friend. Do you think I can recycle the used 10W60 in one of my sig cars? Or bad idea because of contamination? It has around 400Km of use now.
Also I've noticed some spare plugs on the oil filter support, oil temp sensors are cheap, I think I'm going to buy one on amazon or elsewhere, what do you think? My Barchetta has the same oil filter support, I'll put it there after that.
