So just finish the my first oil change on altima with 50k miles on it two days ago. Turn the filter to the wrong direction when i try to take it out, spill the oil when pouring it in, also put in too much and had to siphon some out. Even after two days i still see oil on the ground the next morning, i hope is just the oil i spill slowly coming down.
Where else will engine oil leak other than from the drain plug and the filter?
The drain plug was on pretty tight, after loosen it i can use my hand to unscrew it but after few turns i have to use the wrench again, cant turn it with my hand. Does that mean the drain plug is damage or the thread on the oil pan is worn?
