On a Forester user's group, fellow BITOGer bluesubie turned me on to the fact that many turbo Forester drivers are using this oil because it doesn't lose viscosity to shear as badly as many other 5W30 oils. I see that it seemed to be targeted to diesels, but is acceptable for use in gas engines, too.
Anybody here using this oil in a gasoline engine? bluesubie suggested that it might have a low TBN and the U/VOAs seem to back this up with low calcium and almost no magnesium. Haven't seen any NOACK numbers, but the flashpoint is very high...ditto with cold viscosity numbers, but the pour point is lower than standard M1. HTHS looks attractive at around 3.5.
