Originally Posted By: kschachn
Originally Posted By: Vikas
Either the engine is designed to run on high octane but has fail safe way to prevent detonation if standard octane is used or the engine is designed to run on standard octane and there are no hooks to increase the timing dynamically.
That is a good way of putting it that the knock sensor/s are a fail-safe device. Even then all you can do is retard or advance timing, not change the compression ratio of the engine.
You can also enrich and lean out A:F ratios to prevent detonation or increase power/efficiency which is controlled by the ECU. Rich A:F ratios provide cooler combustion chamber temperatures and prevent knocking. Advancing/retarding timing isn't the only method in modern engines.
