Hello, I posted a little earlier on the brake drum being stuck, now i'm going thru the rebuilding process and running into trouble.
First up it's a 1987 Dodge Caravan (normal length, not a grand), 2.6 mitsubishi 4cyl if it matters, 14 inch wheels if it matters. About 135k miles and spent most of it's life garaged. But then sat a few years cuz I didn't need another vehicle. (inherited this when my mom died and didn't want to just get rid of it)
As I go through the brake system i'm sure the topics will totally change. I posted on the stuck brake drum and overcame that mostly with 6 days of banging and using PB Blaster it finally loosened up and came off. Now i'm seeing I could have a number of other little things to deal with and i'm trying real hard to get this running by monday because I need to get to medical appointments tuesday with it. >_< (my main car unexpectedly offlined)
The two quirks I ran into is first there is an extra U-shaped piece of metal in the hardware kit that never existed originally on the brake drum. I'm pretty sure I know where it goes (the parking brake hardware has a pivot that seems the lever is likely to slide off) but since it's not even in the Haynes manual I don't know the orientation thats appropriate.
The second quirk is that I disassembled the entire brake on the rear left, and the brake cylinder looked perfectly fine with no leaks. THE MOMENT I get everything back on it starts leaking like a sieve! The rubber is still rubbery, it doesnt seem dried out and crusty or anything even though it could still be orig from the factory equip. It just started leaking out of the blue on one side.
I dont know if a) I damaged it somehow, b) pushing and fighting with brake hardware overextended it in one direction, c) do I need to replace it? Pushing on one side of it I feel the piston move in there/maybe it came out too far past some limit and started leaking, but I dont know if that means broke/now replace, or if its fine once pushed back. I got a replacement cylinder I can put in anyway i'm just afraid of repeating whatever I did the first time and damaging a second one otherwise because i'm new to messing about with brake drums.
Btw is there a way to post pictures easily on here? I dont have any photo sites or anything such but it'd be easier if I could show pics.
