Originally Posted By: Gannet167
So to get 80% out of my trans I'd need 6-7 drain and fills. That's 21 liters of fluid and a lot of PITA. Or, since the trans holds about 13 liters, I probably need 10 to 12 to fill it. Or, about half the fluid to achieve the same result.
Interestingly you get a similar, but more effective mix with a cooler line flush.
The cooler line flush mostly flushes what is in the pan, pump and valve body, but when it hits the converter its pumping clean oil in and mixed oil out. So it takes a lot more than people thinks it does to do a complete replacement using the cooler line flush as there is almost always rapid mixing of oil in the converter. It's a lot better than the pan drain/fill that you describe above, but it's never 100% replacement.
