I just got my truck from the body fabricators and wanted to know if anyone is running he Amsoil dual remote bypass oil filter system and if you are what oil are you using? Does it help with regents at all?
It won't make any difference as far as regens go. I use the Motorcraft filter on my '15 along with 10w-30 Deere Plus 50 II, I have a UOA I posted recently in the HDEO UOA section.
Maybe you should read my UOA and make a decision after digesting the data, personally I think if you stay with factory filter you're good because you won't be able to do an extended OC due to regens.
