My brakes were noisy and not smooth.
I put new rotors and pads (both good brands) on and the noise/roughness did not go away.
Upon inspection the slide pins were stuck.
I cleaned the pins + added grease, and the brakes become much better but they are still not smooth and make some kind of noise like "woooooooooo".
Harshness can be felt through the pedal and car.
Checked bearings, they seem fine (no play).
Rotors are not warped.
This does not happen at low speeds (below 20-30mph).
The noise and harshness gets worse with speed, and gets worse the harder I press the pedal.
What could this be?
What should I check next?
What could this be?
