Originally Posted By: Joe90_guy
I think what you said about PCMO & HDDO using the same high SSI VII (you can call it VM, it's the same stuff) might have been true in the past but not today.
The API CJ-4 HDDO specification contains the Kurt Oban 90 cycle shear test. XX-40 oils must stay in grade (ie, have a KV100 of 12.5 cst min) after 90 cycles of being mechanically sheared. This almost certainly means that the oils are formulated with shear stable 22 SSI OCP VII.
My post wasn't saying that HDDEO & PCMO use the same high SSI VII - I was saying that a lot of blenders use the same one for logistical reasons - that means they pick the one that gives them the performance they need for both categories and use that one. This was in response to the posts that HDDEO & PCMO use different ones with PCMO VII being less shear stable. In my experience blenders prefer to reduce complexity by choosing the VII that will perform well in both.
You are right that lower SSI OCP's are commonly chosen. Personally I don't really consider 25 SSI to be extremely shear stable - I often shy away from OCP's in general when going after shear stability in formulas. I prefer more complex molecules of the same molecular weight. (I would never use the Afton product that Shannow linked to)
Quote:
The other thing that you need to bear in mind is that HDDOs tend to contain more additive than PCMOs, particularly ashless dispersant to handle the soot you get in diesel engines. This tends to reduce the amount of VII you need which in turn reduces the tendency of the oil to shear.
I'm not sure where you are going with this, but you won't get any arguments from me on this point.
Quote:
If you're worried about shear on a motorcycle engine, where the engine and the gearbox share the same oil, them I might look for a specialised bike oil which carried some sort of API gear oil spec. Motorcycle oils aren't my thing so I can't recommend anything.
IMO specialized bike oil is the way to go - however I'd focus more on JASO spec vs API specs. They are a little more relevant to motorcycle engine design. Link for details on JASO Specifications
