Originally Posted By: Shannow
Originally Posted By: turtlevette
I finally got this done. King aluminum series main bearings and federal mogul aluminum rod bearings. It was number 1 rod bearing that was spun. It must have been like that when I bought it. There was almost nothing left of the bearing. I resized the cap and trimmed the bearing to fit. I initially used loctite red to lock the bearings in the rod caps. The loctite expands during cure which made the fit too tight to the point that the crank needed 100ft pounds to rotate. So I took it apart and cleaned the loctite out. I decided to pin the bearing on the number 1 cap to help prevent another spun bearing.
We will see how long my unauthorized repair lasts. It has 72325 mi.
turtlevette,
I'm not sure how to say this, but kudos, I can see how you worked through the issues, and was about to suggest pinning the cap, and you were there.
Originally Posted By: spasm3
I see, i guess you know that resizing just the cap means when the cap/rod is reassembled, the hole is not round anymore.
That's true, and in the industry, it's called a "lemon bore" bearing. They are very very much more stable than a plain circular bearing...we get the shape by putting a few 'thou of shims in the half joint, machining it round to shaft diameter +0.0075" per inch of shaft diameter + the shim thickness. Take the shims out, and you get the perfect radial clearance in the vertical plane, and having the two wide points at the part line give a pressure effect that stabilises the shaft.
Turtle has got the same effect by losing the shaft diameter, and closing the radial clearance to get it right.
I'm not predicting a long and healthy life, and would suggest the SAE40 be changed to M1 V-Twin (6.1 HTHS, PLUS plenty of additive).
Turtle done good work.
He asked about my blades a while back...
Sometimes you have to take calculated positions.
Either you're pulling my leg or the universe has just collapsed into a singularity. I initially used the m1 TDT because it was on sale a couple years ago, and the rope seal leaked causing large puddles of oil. I was thinking of using the old redline racing 50 I got for $7 quart on eBay. An ester should keep the rope seal expanded.
But I think I get your drift. Guys like us use our ingenuity to fix things others say are unfixable.
It took huge ones to make that turbine repair and take responsibility to say fire it up! I know how conservative the power industry is and people with the knowledge and confidence to keep the lights on are few and far between. Kudos to you x100 sir.
