I have a 2003 Escape V6 with 50,000 Miles that my daughter uses now and then. I was running 5W20 Pennzoil Platinum but the engine developed a lifter tick when cold. (It goes away when warm) switched to 5W30 PYB in hopes the thicker oil would help but no change. It sounds a bit like an exhaust leak, but I think it the lifters. Engine seems very clean when looking in the oil fill hole.
I need the best snake oil BITOG can recommend to fix this noise, cost is no object!...
