I've driven thousands of Deckmate Deck screws. They came with a matching phillips head bit, but one could use a square bit in them and suffer less cam out/ stripping.
Recently I saw they switched to a torx drive head. While there is even less chance of cam out/ stripping, they do not take driving them at off angles as nicely as a phillips or Robertson.
And of course if one needs to back out such a screw at a later date, one better be able to find the appropriate torx bit, or the job comes to a halt until one is acquired, with a maelstrom of curses thrown during the search.
Whereas if one had even a number 2 phillips in the older deckmates one could still remove it.
but that could be just me
