I think there is more to this story. I want to know like others have said is this the physical pedal assembly itself, the flat metal pad or rubber cover that you put your foot on, the metal arm, or the mounting point where the metal arm is mounted into the bracket?
I almost wonder if this car was in an accident and had serious damage that is located around that area?
