Although ambient temperatures have been quite extreme - 105 - 110 in the evenings and over 120 during the day - the AC on the Envoy isn't quite as efficient as it used to be. I hooked up my gauges and the readings I got were as follows at idle:
Low Pressure Line: 40 PSI
High Pressure Line: 300 - 325 PSI (erratic fluctuation)
The ambient temperature at the time was 108. Does this look like a compressor issue?
