There are 290K miles on the van. The engine will be pulled to replace the engine mounts and oil pan. I'm having the plugs replaced, belt and a coil. Is there anything that you would recommend? Rear engine seal? Transmission seal?
This job is $1700. I don't think this garage will give any breaks for grouping work together.
Another garage did that. Front end work that took 4 hours, they charged me 8 hours full book hour rate by charging me for each item replaced. So much money for pulling rotor and backing bearings. Book rate for replacing the ball joints and other things with it all apart. Ripped off.
Thanks
Thanks
