Current ball joints on my '96 have had shredded boots for many years now and somehow just the occasional spray of cyclo chain lube (lots of moly and graphite) has kept them tight and trouble free. Well, they are just starting to squeak again so I picked up some low mileage a-arms off a late model Cobra (direct fit, better BJ's and better bushings). 17k miles on them. My question is, since they are currently off the vehicle it is very easy to slide a needle past the boot lip at the top of the joint without damaging anything. There is visible grease inside the boot which I can see as the boot is semi transparent; is it worth it to add more? What are the chances the original grease is incompatible with a lithium complex like valvoline synpower? Wouldn't it just be my luck that Ford used something off the wall like bentonite grease and I ruin it by adding an incompatible grease...
