Originally Posted By: 2civics
http://www.blackstone-labs.com
Right.
The only thing I question in your situation is how valid your results will be with the amount of oil change-out you have to do. Some of the guys here will be better able to tell you whether they think you'd get your money's worth from a UOA considering you are burning and replacing so much oil. The analysis costs $25 and is an extra $10 if you get the TBN done. What is the TBN? It's an add on testing that is over my head at the moment (has something to do with testing the additive package and how much further you can go on that oil??) and so the other guys will be better able to explain that as well if you are interested.
2civics, OP has to add oil during his OCI, that is a constant. Once he has the UOA and posts it up, he'll get plenty of comments. It will show the condition of the oil at the time the sample was taken and from the numbers we'll be able to tell if it's time to change the oil, or estimate how much further it can be safely run.
Blackstone, with the TBN (Total Base Number), will tell you both how much active additive remains, and also give an estimate based on other UOAs for that engine, how much further they think the oil could be run.
Right.
