Originally Posted By: KrisZ
Originally Posted By: Lubener
Originally Posted By: Lolvoguy
I shut mine off a few minutes before shutting the car off to dry ou the evaporator. If not, you might end up with that "moldy" smell the next time you start the a/c system.
seems to have kept my a/c system clean smelling
Better yet, run the system in "vent" mode a few minutes before shutting down will dry off the evaporator.
Well, that would only work if the air outside is not humid and if the outside air is not humid, chances are that the air inside the car is not humid as well. Unless there is some physical activity going on
Also, in the recirc. mode and given some time, the air inside the car will actually be less humid than outside since the AC will be able to dehumidify it. Dehumidified air feels cooler than humid air. It's part of the reason the recirc. option is available in cars.
Whether you select outside air or recirc does not have any bearing on the evaporator temperature. It will still be very cold and therefore water will condensate on it.
I do pretty much the same as Lolvoguy does and it does help keeping the moldy smell away. It's a good practice IMO.
No, that is not correct. It is outside air that you want - WITH THE COMPRESSOR OFF - and blown dry for awhile if you really want to monkey with this. The drying action happens when the compressor is off... otherwise it is best to use recirc. in operation as it doesn't keep "soaking" the evap with fresh WET air from outside. Once compressor is off, it's all relative and the surface "drying" occurs BECAUSE THEIR IS NO CONDENSATION ON THE EVAPORATOR OCCURING... On systems that are "auto" unless you are turning off compressor to save fuel or because it is cool enough outside, it is just best to use "auto" mode and pop compressor off if needed than constantly fidgeting with the system. I truly find in most vehicles it works best - and lasts the longest ( moving doors and valves constantly in manual does the system no good, either! ) We find this in the field as well...
BurrWinder
