I have only found threads of people bickering about what type of fluid you can use. What fluid can you use? Does it have to be the FL22 fluid? I have heard that the motorcraft green and the peak extended performance are the same fluid? Can you help explain? I dont want to screw the car up, but the mazda fluid is so expensive.
Thanks
Thanks
