oil for a 2011 VW TDI Golf with DPF delete
yes, but there's no regulation in place to test them. If they look to be present it's ok.
However, the DPF relies on the catalyst to raisethe temperature of the exhaust gassses when regenerating.
Lots of guys are using Rotella T6 on the TDI club forums. I haven't changed my oil since I deleted the dpf/egr/cats, but that is what I was planning to go with. Or the M1 equivalent.
btw what tune are you using? I did a Malone stg 2 and I'm loving it.
I've used T6 and Redline 0w40 in my Malone Stage II 2013 Passat TDI both with good UOA results.
