Originally Posted By: Olas
With a manual, YOU decide when to shift and YOU decide exactly how long it takes. What were your reasons for buying an automatic, especially when you admit that they're known to be no good?
Certainly helpful, if a little blunt.
OP buys a car with known g/box issues and then complains about the g/box and seeks a solution.
Time and cost to have a shop pull, rebuild and refit is equal to, if not more than, sourcing and fitting a manual box which will eliminate the problem from ever recurring.
Then when It comes time to purchase a newer vehicle, remember how many complaints there are about bad shifting on here and how much more control over shift timing, speed, and characteristics you have with a proper box.
I doubt my mission will be successful, but I want to convert as many Muricans as possible to thinking more about their driving, and enjoying it more at the same time..
Swapping a Manual into a auto car is NOT easy & will cost way more than having the automatic rebuilt.
Used 5 speed gear box....Hopefully a good one??
Flywheel & bolts
Clutch & pressure plate
All new clutch hydraulics
Clutch pedal assembly
Clutch switch & related wiring
Reverse light wiring
Shifter & related linkages & fabrication
A PCM out of a manual car
The Mounts & Drive axles may be different?
Most repair shop WILL NOT have anything to do with this crazy plan, The ones that will do it....Will charge you up!!!!!
Yell from the roof tops all you want about how superior Manual Transmissions are too Automatics & Americans are dumb....I find it amusing, This & the PCV thing.
On the original subject, Does a transmission of any make owe anybody anything at 150,000 miles? The OP needs the trans rebuilt, Solenoids & Fluid will not help.
