i just rotated tires in my daughter's yaris. the previous owner put directional tires, so i can only rotate rear vs front. the tires have only little life left in them (at estimated 35000 miles, but not sure when tires were purchased), and right tires have slightly more wear, about 1 mm. the alignment is fine and the tires are wearing evenly otherwise. no problem with tire pressure either.
have you seen it before?
