I bought a Mazda Protege5 last winter for a great price, knowing it likely needed an engine. It smoked very badly until it warmed up, and consumed a lot of oil. The engine was killed from severely neglected oil, the oil rings were stuck from carbon and sludge, and there was a a lot of gunk under the valve cover. The main and rod bearings were damaged as well.
I installed a JDM engine with around 50,000 miles on it. It runs perfectly and doesn't consume any oil. The JDM engine is identical to the USDM engine, with the exception of the pistons (more dome raises the compression to 10.4:1, from 9.7:1) and the camshaft profiles.
The factory spec is API SL/SG/SJ/SH 10W-30. I've been using Valvoline Maxlife and a Purolator Classic filter, at 5k intervals. I've only changed it once since I put the engine in, but it'll be due for another change shortly.
This is a high RPM engine that I frequently drive pretty hard (I take it to 6000 daily). It cruises 70mph at nearly 3500 rpm. It's high geared and doesn't have any considerable low end power. Additionally, I live and frequently traverse lime gravel roads that are very hard on engines. I check my air filter frequently, but I don't want to run an extended OCI because of this. The car is driven around 200 highway miles per week, and 50-100 mixed miles on top of that. I'd prefer to stick with a 5k interval, not into extended OCIs with an oil filter that's smaller than the one on my lawn mower.
Am I running an adequate oil/filter right now? If not, what would be a better choice? Availability is a concern, Walmart is the only reasonable supplier near me.
