If you were maintaining a vehicle with approx 130-140k miles with shredded ball joint boots but no noise or slop yet (and they have been shredded for probably 40k miles) what would you do
1. Continue using the same spray lube and wait for them to develop a problem- hopefully NOT during 0*F winter blizzard.
2. Replace with decent quality ball joint such as Moog, Motorcraft, Napa, etc.
3. Replace a-arm assembly to refresh ball joint and bushings in one shot. Hard to really know the quality of these pieces, it seems now.
I am probably going to default to #1 for now, but I want to have a plan in place and maybe even tackle it preemptively before the weather turns this year. Right now I'm on the fence between Moog BJ's from AAP or Napa brand replacement control arms from, obvious Napa. My concern with the Napa pieces is that it seems they are non-greaseable (which I'm 100% OK with for OEM-level parts) but I'm not sure the extra cost is really worth it. I can get the Moog's from AAP for about $80 total while the arms are listing at $130'ish a piece. Should be able to get a fleet/account discount on that, but not sure realistically how much impact it will make.
Further, it seems like every other replacement control arm option, short of Motorcraft, is Chinese imported, even the well reviewed pieces from Latemodelrestoration...
