I like the fact that the author talks about distortions.
These are mine;
A crankshaft will be progressively loaded higher towards the drive end of the engine, causing "wind-up and let-go" events.
Shifting under power can cause the crank to flex.
Due to harmonics, an engine could have a bad spot in the rpm range.
There are so many variables, that perhaps the best practice when rebuilding engines,
would be to open up the clearances, run a thicker engine oil than popular opinion and make sure the oil pump can keep up with the program.
I grabbed this gem from the article;
"In order to prevent or reduce metal to metal contact,
the clearance should be designed
to produce the maximum possible level of minimum oil film thickness.
I had to read that one a few times to get what he was saying.
