110,000 miles is a long distance for a timing belt. Low end pulleys won't always make it that distance. They sell a Renault here that will break its timing belt at around 45,000 to 50,000 miles if you don't change it at the recommended 40,000 mi. I've heard of Ferraris that break their belts somewhere around 35,000 mi. if not changed at the recommended 30,000 mi.
Your engine is listed as an interference engine. That means that if the belt fails it will bend valves. If the pump is driven by the timing belt, when [not if] it fails, if it happens to seize, it will take out the belt, which will then bend the valves. $$$
I would recommend an Aisin timing kit, but it looks like they don't make one for your engine. Continental does, but it doesn't include a water pump, you need to buy it separately. Continental would probably be my second choice.
