2000 Buick LeSabre
Issue: Left high beam does not work
Question: Is Pin B the ground side of the connector ?
Left high beam connector
Pin B: If I touch the test light to this pin from the positive battery terminal, the test light will not light.
Pin A: If I touch the test light to this pin from a good ground and close the high beam switch, the test light will light.
Right high beam connector
Pin B: If I touch the test light to this pin from the positive battery terminal, the the test light will light.
