'13 Camry with the black oil filter cap which houses the filter element.
Do you think that factory engineers selected 36ft-lbs knowing it'd likely be oily or should I spray the heck out of the threads on the cap and aluminum oil pump housing with brake cleaner to make them a "dry" torque?
Also, where is 36ft-lbs on the scale of "loose (under kill) to too tight (overkill) in your opinion for an oil filter cap with large coarse plastic threads?
