I've tore down the engine on a push mower I've had sitting around for a few years. I got the mower at a yard sale and it started giving me problems two years after buying it. I use it mostly for trimming as I have a commercial grade zero turn mower.
The engine is torn apart and it looks like it needs serious work on the carb and a new set of rings. Haven't got the valves out yet but they aren't looking good either.
I've looked all over and can't seem to locate the model number. Went to the Briggs homepage and saw where they said it should be. Nothing.
It looks to be a 3.5 or 3.75, probably the later, engine. The mower is a standard 22in push type. Vertical crank, spark plug facing front with carb and gas tank on the side. Anybody know what the model number might be? 90900? Having trouble narrowing down my parts search.
Thanks
Mantooth.
Thanks
Mantooth.
