Originally Posted By: Nate1979
LOL. OK, do I need to make a full list of reasons or will just a few key reasons work? I own a Silverado half ton and I don't go around saying it is built like a 2500/3500.
First, most 3/4 tons are built on with the most of same components as the 1 ton models. If I compare 2015 models the Chevy 2500 weighs about 1000lb more than the equivalent Tundra as well as the 1500 series. P vs LT tires, number of lug nuts, semi floating vs full floating axle etc.
Both Chevy and Ford have 1/2 tons that they rate higher than the Tundra, basically as heavy half tons.
Why bother, People believe what they believe. Even IF they are "Built Like a 3/4 Ton", The GVW/GCWR ratings tell a different story, So why have something you cant legally use too it's full potential?
