I'll be doing a timing belt/water pump and a "major" maintenance on a friend's 1995 Camry in a few weeks and his PS pump is leaking and spreading fluid all over the place, I was debating whether to rebuild the OEM pump with a Toyota or Gates reseal kit - but my concern is a worn shaft or just to slap in a reman pump. Problem is, almost all the remans are Cardone and given my experiences with their CV shafts and electrical bits, I'm wanting to stray away from option. Are their PS pumps as bad as most things they make?
