Guys,
For a few months now the reverse gear in my Fiat Marea (cf sig) is sometimes growling - sometimes perfectly silent, but it is more and more growling and it sure won't fix itself...
It is randomly happening (more and more frequent though), cold or hot. Others gears are perfectly ok and operation is smooth.
To see if it can be easily/temporarily fixed, I changed the oil with Mobil 1 SHC 75W90 (previous oil was Motul Motylgear 75W90 which is semi-synth), and it only made things worse. I have a feeling the Mobil 1 oil is more fluid (I know), and that's part of the problem.
Do you think a thicker oil could correct the problem a bit? Like some 75W140 oil?
I can find used gearbox for ~300€, but they come without warranty...I don't like the lottery much so maybe if something could improve the situation.
PS: I have some Castrol Syntrax Universal Plus 75W90 in my stash, but I don't think it will do anythink more than the Mobil 1.
I went to some local garage and they told me to put some additive, I checked the additives in question and they were Teflon or MoS2 additive, oriented to noisy and/or difficult gearchanges (worn out synchromesh), wich my gearbox doesn't do.
Edit: Sorry, post is in the wrong section! Can a mod move it? I was reading in the section and didn't pay enough attention, sorry again, can't delete my post
