My new to me used Nissan Altima with 333k miles, 2.4L 4 cyl with 5 speed MT...$800. Runs good has 3 engine codes, but runs fine.
Owner said the engine has somewhat less miles on it cuz the other owner ran the oil dry and it was replaced with a used engine. The clutch was replaced at some point too. Radiator is brand new, but they used conventional green mixed with who knows what needs a flush.
Heat, AC, Power Windows, Sunroof, Aftermarket CD Player, all work fine, the power locks don't though.
Battery is an Autocraft Silver from 2010 date code, it was so dead that my Noco Genius Boost wouldn't recognize it but after leaving it on for a few minutes it jump started up just fine....Battery is charging right now on 10 amps on my pro logix charger.
The transmission is a bit notchy, will probably give it a new fluid soon.
Not really sure about the fluids, might use Mobil 1 High Mileage 5w30 or Mobil 1 0w40.
