Have a 2002 Ford Ranger. Cast Iron Block
Was lazy in the earlier years and had Mechanic change Coolant.
As always, if you want it done right ......
I have been using Prestone Extended Life ALL Makes, ALL Models since 2010 @ 93,000 miles.
Currently at 128,000 miles.
In 2011 @ 98,500 miles, I had a Coolant leak around Timing Chain Cover.
Had repaired at Dealer - Ouch, much $
Cause of leak - who knows.
Since then, I have been doing a Drain/ Fill of Radiator once a year.
This has been a lot easier for me than doing a Full Flush with the garden hose.
I use Distilled Water / no engine block drain.
So anyway, I am now questioning using Prestone Extended Life.
Ford requires coolant to meet Spec WSS-M97B51-A1
This means using Motorcraft Gold or Zerex G-05
To save money, I would like to use Zerex G-05
Concern: It seems like the chemistry of Coolants can be very confusing.
Questions:
1) Who would be right in using a Universal Coolant ?.
2) Am I wasting money by doing a Radiator Drain/Fill every 8,000 miles ?
... Draining Radiator removes 55% of Coolant.
3) Could I have been wrong using Prestone Extended Life ?
I figure I will use the Zerex G-05 and just continue with the Radiator Drain/Fill.
Any advise or opinions would be appreciated.
Thank you.
Questions:
Thank you.
