2006 Silverado 1500HD 8-lug wheels
I am trying to remove the whole rear caliper assembly since the caliper bolts are stuck and are beginning to strip (Torx T55). I sprayed them with PB Blaster to no avail. They seem impossible to remove.
I asked a shop how much it would cost to do the brakes and they quoted me more than the cost of the caliper. So I want to replace the entire caliper unit without bothering to remove the bolts to access the pads.
I was able to remove the caliper assembly except there is a E-brake cable attachment and I don't see how to disconnect it. At this point the caliper is hanging loose with the exception of the E-brake. Is there a manual or a youtube video explaining how to disconnect it?
