Hi all, This is my first shared UOA here. I'm on a 5 mile commute now, and had bought a 3-pack of Castrol Act-Evo 10w-40 in gallon jugs. The shifting got kinda rough toward the end of the run, and I found neutral instead of 2nd gear more times than I would like. Kawasaki 10w-40 went back in, with a Fram Ultra filter.
Code:
OIL CAE10w40 Kawi10w40 Universal Avg
FILTER PSL14612 HF303
MILES IN USE 8178 8500
MILES 24265 16087
SAMPLE TAKEN Jul 06,15 Jun 12,14
ALUMINUM 35 42 27
CHROMIUM 0 0 0
IRON 20 16 15
COPPER 6 10 9
LEAD 1 1 1
TIN 2 2 1
MOLYBDENUM 6 50 63
NICKEL 3 3 2
MANGANESE 1 1 1
SILVER 0 1 0
TITANIUM 0 0 0
POTASSIUM 1 0 2
BORON 24 51 61
SILICON 17 10 14
SODIUM 4 5 11
CALCIUM 661 1866 1455
MAGNESIUM 966 34 494
PHOSPHORUS 858 846 925
ZINC 1088 1023 1106
BARIUM 0 0 0
Should be
INSOLUBLES TR 0.1
WATER 0 0
FLASHPOINT ºF 365 390 >375
SUS VIS 210ºF 53.4 55.1 65-78
cSt @ 212ºF 8.29 8.79 11.6-15.3
Fuel% 0.5
TBN 5.1 4.6 >1.0
Blackstone notes:
Quote:
I logged the viscosity in as a 10W/40, but it read more in the 5W/20 range, similar to last time.
Some fuel was found, but that's not enough to thin the viscosity out. Wear changed a bit since last year's
sample, but everything is still within the average range. The TBN was strong at 5.1. I've found my shifting to
get rough towards the end of an oil change too. A fresh fill of oil always smoothes things out for my Honda.
That might be a good gauge as to when to change the oil, or you could try 9,000 miles next. A trace of
insolubles shows excellent oil filtration. ~Luke
Code:
MILES 24265 16087
ALUMINUM 35 42 27
CHROMIUM 0 0 0
IRON 20 16 15
COPPER 6 10 9
LEAD 1 1 1
TIN 2 2 1
MOLYBDENUM 6 50 63
NICKEL 3 3 2
MANGANESE 1 1 1
SILVER 0 1 0
TITANIUM 0 0 0
POTASSIUM 1 0 2
BORON 24 51 61
SILICON 17 10 14
SODIUM 4 5 11
ZINC 1088 1023 1106
BARIUM 0 0 0
Should be
INSOLUBLES TR 0.1
WATER 0 0
Fuel% 0.5
TBN 5.1 4.6 >1.0
Blackstone notes:
