When driving cast iron valve guides out of aluminum heads it is essential to either get all of the carbon off the guide or soften it chemically so the aluminum bore is not damaged.
I used to have access to a cold tank, not any more.
I glass-beaded the heads fairly clean, but a little carbon on the guide that is not removed by the bead blasting will do a lot of damage.
I'm looking for a chemical I can put on the guides to reliably soften the carbon.
Any ideas?
Any ideas?
