Name the Fluid and its use
SANTOS, BR
It's a 100% Synthetic Fluid
Density 15C: 820kg/m3
Viscosity at -40C: 1050 mm2/s
Viscosity at 40C: 18 mm2/s
Viscosity at 100C: 5.9 mm2/s
Viscosity Index 320
Flash Point Cleveland: 157C
Pour Point: -51C
So, name the Fluid and its application. No piston pins, just win.
We're getting to it, but another hint is that they're used as in orange fluid eletro-hydraulic systems, moreover french cars...
Modern aircraft hyd fluid are purple in color. Skydrol 500 for example. It's ester Phosfate base synthetic. Not the questioned fluid. Another hint: same spec are used in suspension and power steering for CARS.
It's right there, 157C. And, acording to the spec sheet from the manufacturer. I don't know about the Cleveland method (vacuumed?), though. Isn't ASTM or flame over fumes, I think. Not for heat soak systems anyway.
Composition: 100% Synthetic fluid with 1-decenoate, hydrogen dimer (flash point decreasers), plus, alkoxylated long chain alkyl amine (multifunction as disperant, anti-rust and corrosion, etc). It isn't volatile at operation temperatures (below 100C). Considered harmfull if inhaled and/or swallowed ...
Total Fluide DA?
Composition: 100% Synthetic fluid with 1-decenoate, hydrogen dimer (flash point decreasers), ...
Better look at that again. It's a 2.0 cSt PAO, a base oil.
Total Fluide DA?
Synthetic fluid of orange colour especially developped for electro-hydraulic power steering systems (EHPS) of passenger cars (Peugeot, Citroën, Renault…)
- Approved for use in centralized hydraulics of commercial vehicles requiring a synthetic hydraulic fluid
So, could you elocubrate a little more Molakule? A 2 Cst has a low flash point as 157C?
Nothing to elaborate on, except you had in parentheses that it was a flash point decreaser. That is not correct.
It's a Group IV PAO base oil with a 100C viscosity of approx. 2.0 cSt.
The total formulation consists of a PAO, a multi-functional corrosion inhibitor/detergent/AW, and a polymethylacrylate VII.
You didn't answer my question, again. The 1-decenoate, hidrogen dimmer doesn't make for a lower flash point for PAO base when added to it?
