Hi,
A few years ago I bought a 208 Liter barrel of 10W40 Mobil Delvac XHP engine oil. For easier handling I poured the oil into several transparent 25 Liter polyethylen containers with a hermetic screw cap. Yesterday, for the first time, I opened one of the sealed 25 liter containers because I needed oil for an oil change. What shocked me, however was, at the bottom of the container there was a brownish deposit with covered the bottom slightly. The deposit looks like very fine particles. It has to be some sort of sediment because the container walls are 100% clean. When I try to "rub the particles off" (I cannot reach them through the small cap opening with my fingers) by splashing a small amount of oil around at the bottom, the deposit will not dissolve and stays where it is.
Does anyone know what this is?
I can assure that the containers were 100% clean prior to filling them in the past.
Lucas
Lucas
