Ok guys, I want to revisit this. As stated, I have 3 brand new aftermarket motor mounts installed. There is also a 4th mount which I did not replace because my mechanic visually inspected it and said it still looks good. This one is the transmission hanger. I personally do not think you can always look at a part and just because it looks ok on the outside means that it is functioning properly. I’m not exactly sure where or how this transmission hanger mounts but if it is would that create a lot of vibration at lower RPM’s?
