turtlevette
Thread starter
Originally Posted By: turtlevette
Originally Posted By: 901Memphis
The cheap stuff is downright dangerous. Don't be surprised if someone rear ends you because they couldn't see your brake lights or someone doesn't see your back up lights for instance if you replace those with cheapos. The cheap led bulbs have awful viewing angles.
Don't say I didn't warn you!
I believe you. I'll experiment with cheap smd leds on the front turn signals and stay with good old incandescent bulbs on the rear. I ordered some 60 count smd leds for 2.50 each. I'll report back.
These cheapo led bulbs aren't that bad. I put them on the front and the whiter light wakes the look up. A nice clean bright white light thru a white lens. I didn't like the look as much thru a red lens.
